Windows tool AC27 - dimension
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2023-10-09 06:28 AM
I have a window from the ArchiCad 27 library. I configure it. Everything is fine until... until I change the width of the splay return. If I leave 6cm, my finished and raw dimensions are ok. But if I change the value to put 10 cm, well, my finished dimension bugs... I no longer have the height value. On the other hand, the gross value is ok.
 The result with a splay return of 6cm. The value "253" disappears.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-10-09 06:33 AM
And I just noticed that the height value doesn't match the actual values ​​for the finished dimension. The rating shows 253, when I should have 225
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-10-16 04:42 PM
Hello.
Is anyone else facing this problem? Or is Graphisoft aware of this issue and will it be fixed in the next update?
Thank you for your answer.
