Kamelite
Working with Cumulativ dimensions
Is it any way to make the measures display in the center between two measured points?
[attachment=0]2020-10-21_20-35-21.jpg[/attachment]
.Kamelite
Windows 10, Archicad 27,28 and 29
2 Replies 2
Guru
I have never used cumulative dimensions, but would that not be misleading if it was centred given that the measured distance is at the check mark, not between check marks?
Kamelite
You may have a point there. I've never used them before either.
Thanx 🙂
.Kamelite
