We value your input!
Zero suppression on top elevation autotext
alexanderpault
I made an associative label with autotext to display the top of wall elevation relative to project zero - this works well but I can't seem to turn off the 'zero suppression'. For example, if my wall is exactly 8'-0" tall, the label will only show 8'. Same goes for a wall that is 0'-6" tall - it only shows 6"
There is no parameter in the calculation or working units to change this, and adjusting this in the project preferences > dimensions > "display of zero feet and inches" does not fix the problem. Please see images for all adjusted parameters and an example of the label.
Screenshot 2024-10-11 at 5.02.40 PM.pngScreenshot 2024-10-11 at 5.02.23 PM.pngScreenshot 2024-10-11 at 5.01.17 PM.pngScreenshot 2024-10-11 at 5.00.19 PM.pngScreenshot 2024-10-11 at 4.58.42 PM.png
Operating system used: Mac Apple Silicon Sonoma 14.6.1
0 REPLIES 0
Setup info provided by author
