kmitotk
Zone Label 25?
There is a new label called "Zone Label 25" in the AC25 Label Tool. I thought this label could be associative to a zone and display the zone data. I tried to use it but it doesn't seem to recognize zones at all. It doesn't work as an independent label either. These is no mention of it in the AC25 new feature notes or in the updated Help Center. Is this something still under development but ended up included in the new release by mistake?
Kei Mito
MITO architecture + design
Architect | Graphisoft Certified BIM Manager
ArchiCAD 29 JPN/USA/INT | Windows 11
13 Replies 13
@Ray wrote:
That was it. Updated to build 4003 and the annotation option in the zone tool showed up.
Yes, zones can only be labelled from the second update (build 4013) onwards.
adambar
I have a reverse issue? How do I turn off the zone label? (i want to keep the satmp).
Turn this of before you place any zones.
And for any zones you have already placed, you can just delete the label.
And also make sure to adjust your Model View Option combinations so Zone Stamps are shown (in AC25 Update 2).
