Zone Stamp Font Size
I can change the zone stamp font of the zone name. How can I do the same for the other zone parameters? This question was raised and answered with Archicad 14 but user interface is no longer looks the same. Thanks.
4 REPLIES 4
DGSketcher
Legend
Go to Options > Element Attributes > Zone Categories and change your Zone_Stamp_1 18 to Zone_Stamp_2 18 in the required categories.
This will give you a far more versatile stamp that can change with scale and allows a greater range of font adjustment.
Thanks, DG Sketcher
Zones are not intelligent enough currently to be multi-story zones.
I would probably place two Zone elements, one for each story. Then I would set their height values so that they touch vertically. Also I would set the same Zone Number for both.
_________________
Thanks, Curieroy
