Zones - Text alignment
Hi Guys,
I'm working in V18 and have only just started to use zones.
I cant seem to make the text align to the center though. so as an example, the top text will read "Master Suite" and the text below is to read "CARPET" for the floor finish.
Is there a way to display the text for zones as center aligned?
One more item for zones! Under finishes, they all have a capital to start them off and then they're down to lower case e.g. "Carpet".
Can you set zone text up to all read in upper case? or have some in lower and others in upper?
thank you for your support in advance!
8 REPLIES 8
Eduardo Rolon
There are 2 places were you can edit it. Either on Options-> Element Attributes-> Zone Categories which should apply to all zones or individually.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
By Zone
AC29 US/INT -> AC08
another Moderator
Thanks Eduardo for getting back to me and so quickly too.
I've had a look at your suggestions and unfortunately it would seem that on my PC it will only allow me to justify to the left or right, not center. We're running A18 on a PC, maybe the PC has different options?
Eduardo Rolon
It shouldn't have different settings from Mac to PC but I'll let a Windows user answer.
AC29 US/INT -> AC08
another Moderator
This setting is not the same in all Zone Stamps.
In Zone_Stamp_1 18 there is a center option, but in Zone_Stamp_2 18 there is only left and right justification options.
ahhh!! now, for a potentially silly question. How do you choose between Zone_Stamp_1_18 and Zone_Stamp_2_18? and what is the difference between the two?
Thank you for the reply!
You choose the zone stamp in the zone categories.
Options menu > Element Attributes > Zone Categories
You can set a different stamp for each zone category you have.
As to what the differences are between them - too many to list here.
They just have different parameters available and may display them in a different manner - i.e. on had centre justify text and the other didn't.
You will see a list of all the parameters and a preview of what the stamp looks like in the Zone Categories dialogue.
Tecnica wrote:
Hi Guys,
Hello all
I have the same question as Tecnica.
"Is there a way to display the text for zones (Zone_Stamp_2 18 in archicad 18) as center aligned? "
Please help me !
Thank you.
