‎2014-11-10
09:55 AM
‎2023-05-19
03:56 PM
Gordana Radonic
‎2014-11-10 11:51 AM
another Moderator
‎2014-11-10 11:52 AM
another Moderator
‎2014-11-11 01:59 AM
‎2014-11-11 02:09 AM
another Moderator
‎2014-11-11 06:50 PM
‎2014-11-12 03:21 AM
‎2014-11-12 04:13 AM
Tecnica wrote:You choose the zone stamp in the zone categories.
ahhh!! now, for a potentially silly question. How do you choose between Zone_Stamp_1_18 and Zone_Stamp_2_18? and what is the difference between the two?
Thank you for the reply!
‎2014-12-31 10:53 PM
Tecnica wrote:Hello all
Hi Guys,
I'm working in V18 and have only just started to use zones.
I cant seem to make the text align to the center though. so as an example, the top text will read "Master Suite" and the text below is to read "CARPET" for the floor finish.
Is there a way to display the text for zones as center aligned?
One more item for zones! Under finishes, they all have a capital to start them off and then they're down to lower case e.g. "Carpet".
Can you set zone text up to all read in upper case? or have some in lower and others in upper?
thank you for your support in advance!
