2004-07-21 02:48 AM - last edited on 2023-05-19 12:36 AM by Gordana Radonic
2004-07-23 09:40 AM
Jefferson wrote:Dimensioning needs two points: FROM and TO. If you try to dimension the full circle, there is only one point, that is FROM and TO at the same time. Therefore, BOINK!
The dimension setting at the end of the "standard" palette will only dimension part of a circle, if I click on the circle on the right nothing except the AC "doink" happens, no dice.
2004-07-23 03:29 PM
2004-07-23 06:32 PM
Jefferson wrote:Well ... I really don't see the point of dimensioning the lenght of the perimeter of the circle; you can get it in the Object info and the site guys could not care less anyway; they need the position of the center and the diameter or radius.
Well I have to admit I never thought of the problem from the computer's "point" of view, and as always when ever you "drive" like that you head in an unwanted direction.
