ā2015-08-12
02:54 AM
ā2023-05-19
03:55 PM
Gordana Radonic
ā2015-08-12 02:06 PM
ā2015-08-12 05:46 PM
David wrote:Hi David -
jkershaw:
Try the Identification Label 19, turn on Frame and there is a Circle option under Symbol Label > Label Frame > Frame Shape.
David
ā2015-08-12 07:55 PM
ā2015-08-13 12:40 AM
Sam wrote:help me out... what's the RD label?
Have you tried the RD label with a pointer. It worked for me.
ā2015-08-13 02:03 PM
jkershaw wrote:No, I now see what you want and I don't see a Label that will keep its custom shape when the Pointer is activated. The closest I can get is the NCS Indicator 19, Type set to Fixed Furniture (to get the circle shape), but there is no parameter for the size of the circle. Looking into the 2D Script, the circle size is fixed at ' NCS standard 1/4" '.David wrote:Hi David -
jkershaw:
David
Thanks for the reply. I've tried that one, but it does not allow me to add a pointer to the label. I seem to be unable to have the circle (or any geometry around the text) AND have a pointer on the other end. Am I missing something?
ā2015-08-13 03:08 PM
ā2015-08-13 11:48 PM
Erich wrote:That's just about perfect and entirely workable. Thank you!
You can try the one here Shape Label JM16
