keene kopper
customizing the automatic file naming format during PDF publishing or printing
Hello,
I'm pretty sure this is a straightforward question:
How do I customize the automatic file naming format? I'd like to re-order where the page number goes, as well as add inputs from the Layout Info like the status code input.
Thank you!
AC.22
Mac Book Pro
TV / Film Production: Sr. Set Designer
Art Directors Guild, Local 800
Archicad Latest Version
MacBook Pro (15-inch, 2018), 2.9 GHz Intel Core i9, >32 GB 2400 MHz DDR4, Radeon Pro Vega 20 4080 MB, Intel UHD Graphics 630 1536 MB
1 Solution
If you have your Publisher Set displayed in the Navigator, you can right-click any PDf item in the list and choose the "Rename Item" command. Then you can use some Autotexts to define what the name of the resulting PDF files will be like.
Go to post
keene kopper
thank you!
