defpoints layer
dhnguyen
In AutoCAD there is a layer that is called defpoints, where anything on it can show up, but it wont get printed.
Does ArchiCAD has a similar layer?
I don't want to create a layer and have it turned off on the layer combination.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
The only element that is visible but non-printing in ARCHICAD is the Hotspot. Useful for placing critical snap points. Various on-screen options (e.g. section depths) are non-printing as well.
If you want arbitrary geometry to be visible but non-printing, your only options are to us a layer that is visible in an 'editing' model view, but turned off in the model view that a placed drawing is based on...
or... you can use Trace & Reference and reference a view that shows the layer(s) that hold things that you do not want to print - while the main view describes the printable view. Since a reference can be to the same or another story, a worksheet, etc you have choices beyond layers as to where to place the non-printing information.
Layers is the easiest solution; not sure why you don't want to do that?
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
dhnguyen
I have crazy viewports with all kinds of weird angles. I have to crop the viewport setting and show an outline frame around the viewport.
The only way for it to show up nicely is that I draw lines so I can realign the points to. Then I end up deleting those lines after i'm done so they dont print.
DNguyen
ArchiCAD 18- 25
Don't delete the lines, just put them in a layer that you only turn on when you need them.
Or you can use your layout pages (viewports?) as the trace reference.
Another option is to use a white pen for your extent lines.
White pens do not print - but they will hide anything they sit on top of so you may need to use display order to send them to the back.
