2005-04-17
09:42 AM
2023-05-30
03:26 PM
Rubia Torres
2005-04-18 06:48 AM
2005-04-18 05:15 PM
2005-04-18 07:42 PM
2005-04-18 07:58 PM
dbroughton wrote:The main problem with any computer: it does not do what you want it to do, but what you tell it to do.
Na..... that's not it... I'd already tried that one...
I mean instead of 17997mm the dimension will show 18000mm
2005-04-18 11:32 PM
Djordje wrote:Sometimes lines are on an angle, and therefore not an absolute dimension, how do you do that precise? I Know what you'e talking abount, dbroughton. I've just been doing some steelwork drawings. The fabricators don't want things down to 1mm, they'd be lucky to get within 20!dbroughton wrote:The main problem with any computer: it does not do what you want it to do, but what you tell it to do.
The solution to your problem: you should not have elements at 17997mm, but at exactly 18000. That is what the coordinates are for.
CAD is not manual drafting; you should be precise.
2005-04-19 04:20 AM
2005-04-22 08:21 AM
s2art wrote:Lock the angle and type R.
2005-04-27 03:16 AM
Djordje wrote:Sorry Djordje, I wasn't clear. I know how to use coordinate input, I was referring to geometry results, and sometimes dimensions down to the nearest millimetre are not appropriate and you want to round off. It would be nice to have that option, whether it's 5, 10, 20, 100 or whatever you might need.
Why is that nobody teaches or learns coordinate input?
If the dimensions on angle come as a result of the rest of the geometry, you cannot expect them to be rounded off to 5mm.
2005-04-27 12:10 PM
