dimensioning question
How do i change my dimension settings so that they round up for down to the nearest 5mm.
Dale
12 REPLIES 12
Petros Ioannou
And one more thing,
Have you tried the "secondary dimensions" addon to achieve what you want?
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
I might be wrong, but I thought dimension preferences are stored with view sets now so you could establish a view set for your shop drawings with decreased level of accuracy.
s2art wrote:
I was referring to geometry results, and sometimes dimensions down to the nearest millimetre are not appropriate and you want to round off. It would be nice to have that option, whether it's 5, 10, 20, 100 or whatever you might need.
Cheers
can you dimension the geometry construction method and let the weird dimension float? This way, the fabricators can see there was a specific construction thought behind the drawing and not just some "wacky architect" coming up with numbers...
just a thought
wes
