facing problem while importing ifc model to archicad
ankita dhuri
I am facing problems when importing the IFC model into ArchiCAD; the elements are not visible.
5 REPLIES 5
Have you checked the IFC translator settings?
Have you opened the IFC file in an IFC Viewer to see if it does indeed contain a model?
I don't use IFC files, but these are just a couple of things i can think of that you can check.
ankita dhuri
Yes, but it is not showing my 3D model.
They show in plan?
In the 3D window, are all the layers on?
Are renovation filters set to show all?
Have you zoomed to extents to make sure you are not looking at an empty space?
If you CTRL+A in 3D, does anything select?
Do you have a small IFC file yo can attach (maybe have to zip it) or share on a transfer site?
And there is no need to shout (ALL CAPS).
We all know it can be frustrating.
ALL LAYERS ARE ON
ALL RENOVATION FILTERS WE HAVE TRIED
EVERYTHING IS OK
BUT NOW SOME OF THE ELEMENTS ARE MISSING.
Can you show your translator settings?
Setup info provided by author
