Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
fills
hello i work with archicad 10 and i have a problem with fills. when i use fill 25% or 50% this fill is plotting black, can i fix this problem:
2 REPLIES 2
TomWaltz
I'm not sure. There was a string of posts about that a while back. I recommend using the Search feature to try to find it.
Tom Waltz
thank you i'll try it
