graphics override
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-03-02 04:17 PM
hi all !
any one have a solution for this modeling process ?
one wall and another wall as finishing .
then, I wanna GO so all the walls will be with the same fill, but, no line between them.
tnks
best
claudio
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-03-05 01:45 PM
A complex profile can have as many finishes vertically as you want.
With modifiers you can adjusts the heights of these surfaces without having to create new walls.
You can even turn them off by stretching the height to zero.
Horizontally is another matter.
You have to split the wall.
But you can use the same wall composite with modifiers and adjust the height of the bottom material to zero.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-03-14 05:49 PM
hi barry !
I used to use complex profiles, but then, I started to have quantifications problems
It was in Archicad previous versions..., I will teste it...
tnks
c
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-03-14 05:49 PM
nop, doesn't work...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-03-14 07:33 PM
For those schematic plans I just go for a graphic override turning cut fills into a Solid Fill, same pen color as wall outline fill.
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
