Jan Mi
how to get better results in section's Line weight
My sections have Marked Distant Area on, but I need to further more edit some lines to get better results in my presentation drawings.
I have been exploding into current view and manually editing the lines I want but often find errors or have to make some minor changes in the design.
The work around I found that is working for me is:
1. I Find and select the edited Lines and copy them.
2. Explode into current view edited section
3. Paste edited Lines on top of the drawing [i mostly leave the original lighter LW from the edited section behind the edited thicker LW]
Is this the way I should be doing it or is there a legit method?
[I attached an image of the typical line changes I do]
macOS 26 (Latest Build) - Archicad 29 (Latest Build)
1 Reply 1
Eduardo Rolon
Jan,
There is a trick to archive this without exploding lines. You will need 2 aligned sections (one will be hidden in Floor Plan).
First section will have:
- 1. Elevation with Pens from the Objects (LW 01)
- 2. Distant area with First Pen Set Override (LW 02)
- 3. This section will end at the point were the other section Starts so it is limited horizontally.
Second Section:
- A. Place were First Elevation ends.
- B. Override Pens for first area (LW 03)
- C. Set Distant area and new Pen Override (LW 04)
In your layout place Section 01 in front of Section 02 and they will remain live.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
