is there a way to . .. unlink 3D doc
Is there a way to somehow unlink 3d document from rest of the model.
I want to play around with, lets say this 3d of stairs and i dont want to this cnahges in 3d impact my model. (this is AC13)
this could be wish too . . .
5 REPLIES 5
Eduardo Rolon
Copy + Paste.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
i wish that drawing can stay 3d document /i dont want to turn it to the lines and fills. I stoped doing that 3 years ago
I wannt it to be 3d document unlinked from model . . . no lines but but real 3d object !
Eduardo Rolon
You cannot pretend to unlink a model and for it to remain "linked".
Why don't you create another copy of the stair model and then 3D document that one.
The answer is still Copy + Paste.
AC29 US/INT -> AC08
another Moderator
U see, then i dont need 3d documents at all, cos i can alwys do that with marquee tool...and put 3d drawing as independed detail...
I dont want to create more 3d then i need and i think that this is not a rocket sicence to be part of 3d documents,Some kind of unlink from model...
When you create copy of that 3d then archicad will awys use that elements in schedules and i will lose time trying to remove these copy parts from schedules, i will loose time in 2d and 3d redrawings, i will have something that i dont need !
I want to use archicad as BIM nothing less and nothing more so thats why i want 3d documents to be somehow unlinked from model, cos u can do intersting 3d details that can be very helpfull for someone that use them.
But dosnt matter anymore cos i cant get what i want . . .
owen
So you want to unlink the 3D Document so it remains 3D but has no connection to the ArchiCAD model?
Nice idea but i think this is related to the 3D in Worksheets wish .... as in currently there is no 3D space in ArchiCAD that is independent from the Storey-based model space, which i think would be needed.
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
