linked marker without callout box
(new AC user!)
One of the things I really like so far about AC is how it allows me to cross-reference everything in the drawings set, and it updates the links automatically when I rearrange the layout sheets- section tags, elevation tags, etc. all keep pointing to the new correct locations. One item that I still haven't really figured out is how to reference a detail without graphically defining it. For example, in the old days, we used to type in a note
ROOF ASSEMBLY AND EAVE CONDITION SIM. 1/A3.1
But then if I moved that referenced drawing to sheet A3.3, I'd have to remember to update the note (and any like it) manually. My question then is, is there a way to use autotext to make the "1/A3.1" automatically linked to the layout in question? The closest I got was to use a Linked Marker object, which is pretty satisfactory. But I can't find a way to get it to give me just the marker, without a bounding box/callout graphic (see attached screenshot). Is there a setting that I need to make that happen?
Or, better yet, is there a way to get a linked text callout in the Text object?
thanks
Link
Right Click on the Drawing and select 'Set as Autotext Reference'.
Then when you're editing text you can find that reference as a Category for Autotext, and select a dozen different options.
Link.
David Maudlin
jfanjoy:
See also this thread:
Custom Detail Marker
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Link.
That is amazingly, awesomely, breathtakingly cool. Thanks for the info, guys.
