not published layers
some of my layers will not be published. totally 3 layers (objects,hatches) do not appear in the plotmaker file. during the time I am publishing the layers are visible, but they don't appear in the plotmaker file.
Jens
6 Replies 6
Are you publishing a view that was created with a named layer combination, or does the layer combination read as "custom"?
If the view uses a named combination, and those layers are visible for that combination, then I don't know why you would see the behavior you are seeing.
HTH,
I would ask the same question as Karl:
Set up what you want to see in ArchiCAD; then redefine the view that has been imported to PlotMaker; there should be no problem.
If this doesn't help (my comments and Karl's), email me and I will look check it out for you.
Woody
I am publishing not a named layer combination, it is "custom".
Jens
Djordje
Tip:
ALWAYS,
I mean
ALWAYS
name your layer combinations and display options!!!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje wrote:
Tip:
ALWAYS,
I mean
ALWAYS
TIP? This is a RULE!
It works with a named layer combination. Thank you for this rule.
Jens
