ā2005-01-05
08:28 PM
ā2023-05-26
12:15 AM
Gordana Radonic
ā2005-01-06 01:37 AM
Jens wrote:Are you publishing a view that was created with a
some of my layers will not be published. totally 3 layers (objects,hatches) do not appear in the plotmaker file. during the time I am publishing the layers are visible, but they don't appear in the plotmaker file.
ā2005-01-06 03:22 AM
Karl wrote:Set up what you want to see in ArchiCAD; then redefine the view that has been imported to PlotMaker; there should be no problem.
Are you publishing a view that was created with anamedlayer combination, or does the layer combination read as "custom"?
If the view uses a named combination, and those layers are visible for that combination, then I don't know why you would see the behavior you are seeing.
ā2005-01-06 06:03 PM
ā2005-01-06 06:29 PM
Jens wrote:Tip:
I am publishing not a named layer combination, it is "custom".
ā2005-01-06 07:12 PM
Djordje wrote:TIP? This is a RULE!Jens wrote:Tip:
ALWAYS,
I mean
ALWAYS
name your layer combinations and display options!!!
ā2005-01-07 12:26 PM
