pen weights not printing correctly
When I print the pen weights all come through as super heavy - 1.4pt (I know this as I have opened the pdf drawings in adobe illustrator to check). This is the same regardless of printing to pdf or printing to our canon inkjet ix4000.
The pen weights are set correctly in both the view properties and the layout properties.
We are using archicad 13 on Mac, however also had this problem with archicad 11.
We need to work out how to get pen weights to print correctly...
Help!?
10 Replies 10
Thomas wrote:
I realise what I meant to ask is, if possible, where to set a general default override for all drawings before you place them?
Same way you override a modeling or drawing tool settings. For once there is a clean consistency by GS.
