printing letters are scrunched
When I publish to pdf and then print out a reduced size all of the lettering gets scrunched into blobs as if they all printed one on top of the other. This did not used to happen.
1 REPLY 1
David Maudlin
wfroslansky:
I've run into this occasionally. The solution I've found is in Acrobat Reader:
1. Select Print..., the Print dialog box opens
2. Click on the Advanced button (middle top of the dialog box)
3. Check the option Print As Image
I've mainly run into this when rotating a sheet to print on my HP T120 large format printer.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
