JasonC
problem opening file in current version of archicad
Hi Team
Currently have an issue on my windows 10 pc where if i double click an archicad .pln file it will open in an older version of archicad 21 instead of the vfersion im currently running v25
i have already right clicked on a .pln file and gone open with, then browsed to the archicad 25 launcher, (& always open .pln files with this) but even still it defaults to opening in AC21?
anyone know of a fix for this?
Currently im having to open AC25 first then browse to the file location instead.
1 Reply 1
Try this (this is for Windows - might be the same with a Mac?).
In the Archicad program folder you will find a 'Graphisoft Shell Extension' folder.
In there is a 'Register.bat' file.
Run that file.
You may need to restart your machine afterwards.
This may or may not work.
What you described in your post should have worked also.
