Peter Tsao
publisher setting but the documentation collapse
When I try to set publishersetting,because I want to publish PDF, but the documentation collapse.
help me and TKS!
Hi Peter
I don't fully understand the question, but you mention Publishing and Documentation Collapse.
I wonder if these settings are what you are after.
Hopefully, on your OS, in your language, you can compare and the text will make sense.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
