saving EPS files in archicad 10?
we jumped from archicad6.5 to archicad 10 a while back, and are still experiencing culture shock.
We used to save a lot of plotmaker files in EPS. format for graphic purposes, as saving in JPG format never worked.
However, now in AC-10, there is no option of saving as EPS, and either saving as a photoshop file or publishing a photoshop file gets terrible resolution no matter what I try.
Is there any way to save high resolution files, apart from saving as a pdf and resaving it again?
by the way - i'm happy to finally use this forum - lots of interesting stuff here!!...
1 Reply 1
Eduardo Rolon
Conceptually Pdf's are the heirs to EPS files so once saved to pdf you don't have to convert them to eps.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
