sections and elevations showing in plan view
so sometimes some of my projects, size not being a factor, get the sections or elevations embedded into plan view when i try to access a section or elevation. and from then on that section or elevation cannot be erased even if i delete the 3d model. nor can i see my plan in plan view when i close the section. I have submitted bug reports but was curious to see if someone else has had this issue?
i should add if i copy the whole project into a new drawing then every works fine. sometimes forever and sometimes for a couple of days before happening again
10 REPLIES 10
So I was having some other random archicad crashes. I ended up completely uninstalling and deleted everything i could find archicad related on my puter. redownloaded the current install file and the latest update. no move random crashing, and now the files that had this issue work just fine.
