surface of 3D tools in floor plan
L_K_mak
Hi all,
Is it now somehow possible to show the surfaces of the 3D elements in the floor plan?
(without layering axonometry or 2D fills)
We like to draw our interior planning with surface representation and would like to be able to adapt the floor plan look to our views.
Thanks,
Mara
ARCHICAD 23 FULL | Windows 7 Professional | Germany
Ahmed_K
The short answer is no
the Long answer is ..
create image fills similar to1 your surfaces .
create graphic override ruls by surfaces
and assign them to elements
Element = slab and Surface is woodplanks  = > Replace stab covering fills by a woodplanks image fill
Archicad 27
Windows 11 professional
1 REPLY 1
Ahmed_K
Archicad 27
Setup info provided by author
