text rotation
dhnguyen
How do i change the setting on the text so that it can read from bottom to top instead of top to bottom?
Please see attached image.
I tried mirroring the text but it doesn't mirror.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Erwin Edel
You probably have 'Always Readable' ticked, which makes it conform to the 'unwritten rules' of how text should be displayed under certain angles.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
There is no attached image.
Erwin Edel
www.leloup.nl
Windows 10 Pro
dhnguyen
thank you!
DNguyen
ArchiCAD 18- 25
