dhnguyen
Edit Selection Set tool
I want to select 10 lines that are on different layers and color and consolidate them into 1 layer and color. So I selected them and used the edit selection set tool (or the hammer) and check the box "modify auto-labels' layer and color", it doesn't work. Am I doing something wrong? or this there another way to do this?
these are all 2-D lines.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Eduardo Rolon
Taking a guess. If one of the lines is already on that layer then sometimes AC will not process the other ones. Try changing them to another layer first (hit ok) open Edit Selection again then change it to the one you want.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
