I Can't Extrude Morphs Together Why?
Sefa Yakut
Hello,
When I am trying to extrude Morphs together, I cant. If morphs are in group you cant extrude them together. If you select morphs with selection tool, you cant extrude them together. If you want to extrude them together you need to select morphs one by one. Why? This is awkward.
Operating system used: Windows Build 5060
2 REPLIES 2
I guess the reason it works this way is that it has not been programmed yet to detect that the faces of individual Morphs are all in the same plane and they could be extruded in a single step.
Such editing of multiple elements at the same time works in Archicad in the case of polygonal elements, but apparently, not in the case of Morph.
There are many similar tools in Archicad that have a lot of potential but cannot be used efficiently. Although I have been using Archicad for many years, I cannot understand that even such simple tools are not fully developed.
Setup info provided by author
