view vs layout text discrepancy
I sent a preliminary .pdf to a consultant, and noticed it had a strangely placed text block. Assuming I'd accidentally moved it, i went back to the plan view and... it was in the right place! Checking the Layout of the drawing sheet, though, it shows up in the wrong place. Any ideas why it would do this? Its the only text block with this problem. Here's a screenshot of the two (view tab, layout tab) at the same time, showing the different position. Oh, and there are three other identical text blocks on other columns that aren't behaving this way.
Erika Epstein
Could it have been mirrored, or rotated? That would change the anchor point.
What happens when you delete it and replace it with a new text instance?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks Erika, that 's a good fix. It still doesn't really explain why it happened in the first place, but working with CAD (or computers in general) is sometimes like that. I'll keep my eyes peeled for if it happens again, and look for recurring patterns.
