2022-06-07 05:29 PM
I've been using Archicad Sine V4.1 in 1992. I've upgraded off and on over the years. I recently switched from V22 to V25 and I'm not happy. Had already seen little improvement from 19 when I went to 22. here is my list of complaints after a month of using V25. some are carry overs from 22
Complaints of v25
BTW the stairs still don’t work worth a dam I still use the stairs from 19 or make my own.
I have finally been able to make one rail work but still can’t get it to do vertical pickets
I'm using mac pro16
2022-06-08 03:34 AM
3. Work Environment setting.
2022-06-08 03:37 AM
6. It does not necessarily mean the library needs updating.
I means there are 'Warnings' in the Library Manager' that should be addressed.
2022-06-08 03:45 AM
14.
2022-06-08 03:47 AM
15. Only when you have a cover fill turned on.
No cover file - there is no surface for the magnet to select.
2022-06-08 03:54 AM
18.
2022-06-08 09:08 AM - edited 2022-06-08 09:16 AM
Number 5:
To turn off dumb preview pop-up in tab bar:
Options/Work Environment/More Options/
Uncheck "Show Preview in Tab Bar."
It took me years to make peace with the tab bar. You need to get really disciplined with your view settings. They're useful later in the project when you know what you need, but kind of a pain to manage in the early stages. One thing that helped was activating the (still) experimental "Enable Linked Tabs." feature under More Options. This allows for global changes in all tab views, which is especially helpful in early design development.
Also, when you off the tabs you lose the Pop-up Navigator button which for some reason is tied into the tab bar. Having the navigator as a pop-up reduces clutter and frees up real estate.
2022-06-08 09:41 AM
Also if you do not want multiple elevations, multiple sections, multiple layouts, etc., you can turn off these options in your work environment.
Then you will only ever have one TAB for each view type.
Cuts down the number of TABs, but means you can only have one elevation or section or layout open at a time.
Open another elevation and the current one will close.
2022-06-08 11:37 AM
So that the beam moves up or down as beam reference axis changes from top to middle or bottom.
2022-06-08 03:37 PM
Stairs are not that hard. They are quite intuitive once you understand them.
But most of the rest of these are pretty valid issues.
I ended up writing my own cabinet and appliances.
Even a stair tool until they released theirs.
