window projection & sheet index
dhnguyen
1. I'm not sure why my window in the basement is projecting 4.5" out of its foundation wall. It looks fine on the floor plan. please see attached image
2. I want to create two different sheet indexes, one is for a schematic set using 11X17 paper and the one is a construction set,using 24x36 paper.
If I update the sheet index for the 24x36 set, the 11x17 sheet index also gets updated automatically, how do I change the criteria so that each set gets updated by its own different set?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Guru
Is the basement wall a Complex Profile?
I believe it is a complex profile wall issue.
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=62812
You may have some success by setting the "Opening" line position in the complex profile.
