GDL
AC_StoryNumber as integer
Bruce
I don't know why, but the parameter AC_StoryNumber is a TEXT type, even though the story number will always be an integer.  This makes it unreliable to test in GDL whether the current story falls inside / outside a selected range, particularly when testing for negative stories (e.g. IF AC_StoryNumber >= -2 AND AC_StoryNumber <= 6 THEN).
Is there any way to query the current story (in a Story Marker, in this instance) to return an integer?
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
3 REPLIES 3
DGSketcher
Legend
@Bruce You could try using the SPLIT function to extract the Integer value. Have you looked at using Request with "STORY_INFO" to deliver comparison values?
I used the elevator object to learn how to get all the story info.
Bruce
Thanks for this - unfortunately it doesn't solve the fundamental problem of Archicad returning a text parameter for the current story in the Story Marker.
The way I solved it was to create a separate array filled with the story numbers as integers, then run a loop to match the current story (it will find an equal to with a string, but not a less-than / greater-than) with the array value.  Then I declare a variable with that integer.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
