2021-06-18 05:16 PM - last edited on 2021-09-14 09:06 AM by Noemi Balogh
2021-06-19 10:08 AM
2021-06-21 03:53 PM
2021-06-29 08:47 AM
2021-07-06 07:03 PM
2021-07-06 07:50 PM
2021-07-06 08:19 PM
2021-07-07 10:19 AM
runxel wrote:I apreciate your comments, but have you read my description of the problem? I need every layout to be different, that is the task, that is what I am paid to do. I want to automate this, because it seems simple enough - I have a database mit data and a large number of layouts with unique IDs. I need to show different data from the database on each layout - depending on the layout ID. (Layout 1 - row 1 from the database, Layout 2 - row 2 from the database and so on.)
What I do myself is, that I neither have my title blocks on the layout or the master layout.
Instead I have them in worksheets and I place them.
Mostly on the master layouts, still. But on the other hand I really don't need to have every layout be different.
Maybe this is an XY Problem?
2021-07-07 11:03 AM
jan.filipec wrote:I did, but it was not comprehensible. 🙂
2021-07-08 09:30 AM
Podolsky wrote:(I said position ON the layout-sometimes we have to add some information to the layout and move the block a bit-that means clicking through hundreds of layouts and moving them manually right now)
Also you can use txt files (or files with GDL extension, that is txt file but can be a macro), or XML, placed into embedded library as small data base and point if exchanging information between library parts. This way you can control change of several objects by changing only one of them.
