Mario Sacco
Ask a MVO setting more parameters with a single command?
Is there a way to ask a MVO setting more parameters with a single command?
It seams that asking many parameters on multiple objects affects on speed.
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "sl_random_variation", sl_random_variation)
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "sl_surf_panel_a", sl_surf_panel_a)
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "sl_bimx_increase_pan_thick", sl_bimx_increase_pan_thick)
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "sl_panel_offset_box", sl_panel_offset_box)
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "sl_panel_lamier_thick_box", sl_panel_lamier_thick_box)
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "gen_thick_strut_pan_thick_tot", gen_thick_strut_pan_thick_tot)
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "sl_panel_thick", sl_panel_thick)
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "sl_panel_doghe_thick", sl_panel_doghe_thick)
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "sl_panel_doghe_width", sl_panel_doghe_width)
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "sl_panel_doghe_overlap", sl_panel_doghe_overlap)
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "sl_panel_doghe_angle", sl_panel_doghe_angle)
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "sl_panel_zinc_thick", sl_panel_zinc_thick)
_bSuccess1 = LIBRARYGLOBAL (macro_MVO, "sl_panel_zinc_offset", sl_panel_zinc_offset)
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
0 Replies 0
