2022-06-20 06:03 PM
It's saveas from 25 to 24.
Does the GDL generated in 25 not go to 24?
Solved! Go to Solution.
2022-06-22 02:33 PM
the last version of the LP_XML_Converter on Windows was for Archicad 13.
There I created in the main folder where the Converter is located, 1 folder named "gdl", one folder named "xml". In the main folder I aditionally placed 2 file links.
Put the gdl file in the gdl folder and run the file link "... gdl2xml" not by double click, but by rightclick and run as admin.
GDL to XML goes visa verce.
An example file structure you can download here:
https://download.b-prisma.de/downloads/LP_13.zip
2022-06-22 04:42 PM
Thank you so much ^^
