GDL
SOLVED!
GDL - IF using B parameter - Incompatible types
thomaslodge
Hi all,
I'm trying to create a GDL object for British gypsum studs but am running into a problem when using IF command to determine another parameter.
So an acoustic stud has a width ( A ) of 42 mm for a stud depth ( B ) of 43mm but a width of 44mm when any other depth of stud is used. I've tried the code below but get an Incompatible types error when I run a check.
How can I get this to work? I also need to do a similar action for gauge which has the added issue of needing to be editable for some stud depths. 
AC user since 2006. Using AC28 currently.
1 ACCEPTED SOLUTION
Solution
Xandros
Hi
you need to remove the quotation marks in line 51. You just need those in combination with VALUES
It should look like this:
if B = 0.043 then
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
3 REPLIES 3
Solution
Xandros
Hi
if B = 0.043 then
Thanks. This worked albeit with a precision error.
eps=.0001 (master script)
if B-.0043<eps then
