GDL
GDL Intelligent Suggestions
According to the release notes of AC27
"The introduction of new code-focused improvements will enhance your script editing experience:
  • When writing your code, a list with intelligent suggestions based on your typing will appear next to the code line to help you. By reducing the need to type the whole expression, auto-completion will save you time and ensure accurate syntax, avoiding script errors.
MatthewJohnson_0-1741597727404.png"
However I've never been able to get the intelligent suggestions feature to work. Is there an on-switch somewhere that I am missing?
Matthew Johnson - POWE Architects
AC4.5 --> AC28 & Revit 2016 --> 2023
Asus Zenbook Pro 16x i9-13900H w/ Nvidia RTX 4070 4K dual, Windows 11 64bit + Quest3
I'd rather be sailing.
Use ctrl-space to turn the suggestions on
Apple M1 Max 32 GB Ventura
AC27
4 REPLIES 4
Turit
While typing, select the one that suits you from the pop-up list.
AC27
Carrast
And you have to push ctrl + space every single time you want to use this function? Thanks but no, i am slowly starting to miss the old text-based editor...
its intelligent... but lazy
Setup info provided by author
