Mark Chen
GDL can't read profile list
Hi there,
Please check attachment.
This GDL works in AC26 to pick up a profile in current pln file.
But in AC27 none profile can be read from the file. PROFILETYPES_MASK ni not working
Regards,
Mark
7 Replies 7
Funfun Yan
Maybe it is a bug.
A bug or a change in the command that I haven't read about yet.
I have an object that uses profiles and works fine in 26.
But in 27 the list of profiles is blank (I haven't been using 27 yet so haven't noticed).
The object still works and the one available (default) profile is fine.
If I use a different profile in 26 and then copy & paste that to 27, it will show only that new profile.
And another odd thing is, if I open the script and look at the parameter list in 27, it appears to be working just fine.
Peter Baksa
This is a bug, I will report it.
The problem is with the UI. If you add a graphical UI using ui_infield for the profile parameter, it will work.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Thanks Peter.
jp
 Man, I can't even work in the Interface script.  The new GDL editor is completely clunky. I can's scroll down with my mouse.  Script takes an eon to load.  Give me the old interface back please!  Line numbers are great, but not if I can't move about the script.  Hopefully just a weird session.  Will reboot and hope this works better.  I have one part that works fine, and another that doesn't.  Neither have an interface script.  Difference is that one is an object, and one is a door.
Many Thanks, JP
John Peterson, AIA
Dalgliesh Gilpin Paxton Architects
Archicad 7-21 US
PC and iMac
jp
Happy to report it was computer issue in regards to editing the script.  It was the first GDL i had accessed in 27 so I was nervous the new interface was clunky.  After restarting everything, all is working smoothly.  Adding a basic UI to see if that fixes the bug..
Many Thanks, JP
John Peterson, AIA
Archicad 7-21 US
PC and iMac
jp
Any progress on this bug?
Many Thanks, JP
John Peterson, AIA
Archicad 7-21 US
PC and iMac
