Yeojin
How to get the height of each column segment
I want to create a label that shows the cross-section information of a multi segment column and each segments height.
I was able to get the width/height of the cross-section using the COLU_SEGMENT_INFO parameter, but not the height of the segments.
Using the COLU_HEIGHT parameter, I can only get the overall height of the column,
How can I get the height of each segment?
If anyone knows, please let me know.
3 Replies 3
Jochen Suehlo
Did you try COLU_SEGMENT_INFO with :
  • .segments[n].crossSection.startHeight
  • .segments[n].crossSection.endHeight
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
Yeojin
I tried it but it showed column's crosssection size only.
COLU_SEGMENT_INFO.segments[n].crosssection.startWidth
COLU_SEGMENT_INFO.segments[n].crosssection.startHeight
COLU_SEGMENT_INFO.segments[n].crosssection.endWidth
COLU_SEGMENT_INFO.segments[n].crosssection.endHeight
Peter Baksa
It is COLU_HEIGHT, but you can get the information for one segment only or the whole column, based on whether the label points to a segment or the whole column.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
