LeeJaeYoung
If I make the bathroom an object, will there be a problem?
Walls include mortar and tile
ceiling and ceiling molding
Includes toilet, sink, shower and shower booth.
AC27 on window 11
1 Solution
DGSketcher
Legend
Yes if you want to easily add and manage BIM data or schedule the individual parts within the object. It can be done, but there is a limit to the number of Parameters in a GDL object.
This is a situation where you would use Hotlinks (or instancing if we had it).
Go to post
5 Replies 5
DGSketcher
Legend
LeeJaeYoung
Are you saying that the value is reflected in the schedule, such as when calculating the area or volume of a wall or tile?
AC27 on window 11
When you say 'save bathroom as an object', do you mean as a GDL object or do you really mean as a hotlink module.
As a module, you will still be able to schedule the individual components.
As an object it will just be '1 x bathroom' - it won't have individual elements.
Unless you script the quantity of the elemnts into the object and save the values as parameters that you can then add to your schedule.
I would not consider doing this.
LeeJaeYoung
Then, if you make adhesive mortar and tile with cwall, can't you get the volume of each from the schedule?
AC27 on window 11
Lingwisyer
Guru
Not if you save it as a .gsm. As far as AC is concerned, once you save elements A + B + C as a gsm, they cease to be elements A, B and C and become a singular element, D.
This will not work is many cases as you cannot tabulate the results. ie. for two bathrooms it will read "2x Two Taps" rather than "4x Taps"
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
