Robert Nichols
NCS Drawing Title 23 - Can it be positioned to cell?
I can't seem to set an NCS Drawing Title to be positioned to a cell on the layout. When I select "cell" on the position pulldown menu, then all the parameter options disappear in the dialog box. If I save the setting at "cell", there is no visible affect on the title placement, and if I reopen the drawing settings, it position value is reset to "drawing".
Does this feature not work with the NCS titles?
Mac Studio, 32gb ram, ArchiCAD v26 (Apple Silicon) MacOS 13
1 Solution
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi All,
First, I would like to apologize for the trouble that you are having with this issue!
Unfortunately, I cannot tell for sure when a library update is made for USA version, but I found the workaround for this issue in our database already. Here is how you can fix the titles until an update is available:
- Duplicate and open the NCS Drawing Title 23 (or NCS Drawing Title 2 23)
- Click Master script
- Delete the independent 3 lines:
if iTitleFitMode = FITMODE_CELL	then
       intLinkTitleWidth[1] = FITMODE_LENGTH		: stLinkTitleWidth[1] = `Length Parameter`	: picLinkTitleWidth[1] = 0
endif
- In NCS Drawing Title around line 129 to 132
- In NCS Drawing Title 2 around line 122 to 125
I attached a screenshot showing where to delete the line, also include in the zip file my own modification for the 2 drawing titles. Thank you for your understanding!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Go to post
5 Replies 5
GSNA tech support reports that this is a known bug with NCS Drawing Title 23 (among others). Try using NCS Drawing Title 22 from the AC 22 USA library until a library update is issued some time in the future.
Robert Nichols
Thanks, Karl.
toofuerte
So, are we going to get an update on this issue? I found a seperate error reporting with other aspects of the NCS drawing titles. There is a work around but does not help with the cell settings.
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=69018
Gerald Acton "Gary"
Acton Design Services
Windows 10 PRO 64 bit
i7-5820K @ 3.30ghz 32GB Ram
Nvidia GeForce GTX 1650 4GB Ram
AC 19 - AC 28
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi All,
endif
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Robert Nichols
Thank you for posting this workaround.
