‎2024-10-10 11:50 AM - edited ‎2024-10-10 04:22 PM
Hello everyone,
Can you please give me an example of a short script of the UI_INFIELD{4} command to create 3 or 4 "Push icon radio control" (method 4) using matching images
THANKS
Solved! Go to Solution.
‎2024-10-10
04:34 PM
‎2024-10-12
06:03 AM
Hi @Sofiane LPAF ,
Assuming "abcde" is an integer type parameter...
In the Parameter script :
values "abcde" 1, 2, 3, 4
In the Interface script :
ui_dialog "Options", 520, 300
cell_width = 124
cell_height = 93
choices = 4
ui_infield{4} "abcde", 5, 5, cell_width*choices+10, cell_height+10, ! coordinates, dimensions
4, "xy3.png", ! method, picture
choices, 4, ! pictures, rows
cell_width, cell_height, cell_width, cell_height, ! cell, pic dimensions
1, "", 1,
2, "", 2,
3, "", 3,
4, "", 4
Attached, updated versions of your picture with some transparency so there the button behavior is still visible. xy2.png has 0 white background while xy3 keeps the white background within the contours.
‎2024-10-10
04:34 PM
‎2024-10-12
06:03 AM
Hi @Sofiane LPAF ,
cell_width = 124
cell_height = 93
choices = 4
1, "", 1,
2, "", 2,
3, "", 3,
4, "", 4
‎2024-10-10 07:46 PM
I thank you very much for your help, clear and precise, it works very well. Thank you once again for your time, see you next time!!!
‎2024-10-11 09:56 AM
Good to know it worked ! If you can, please mark my previous post as solution so people see your question as solved if they look for the same answer 🙂
I would also advise to resize the pictures beforehand so they look cleaner in the UI. If the resizing is done with GDL in Archicad, the .pngs will look blurry.
