GDL
Need a UI_INFIELD{4} (method 4) Example?
Sofiane LPAF
Hello everyone,
Can you please give me an example of a short script of the UI_INFIELD{4} command to create 3 or 4 "Push icon radio control" (method 4) using matching images
THANKS
MF BIM
Hi @Sofiane LPAF ,
Assuming "abcde" is an integer type parameter...
In the Parameter script :
values "abcde" 1, 2, 3, 4
In the Interface script :
ui_dialog "Options", 520, 300
cell_width 	= 124
cell_height = 93
choices		= 4
ui_infield{4} "abcde", 5, 5, cell_width*choices+10, cell_height+10,	! coordinates, dimensions
				4, "xy3.png",										! method, picture
				choices, 4,											! pictures, rows
				cell_width, cell_height, cell_width, cell_height,	! cell, pic dimensions
				1, "", 1,
				2, "", 2,
				3, "", 3,
				4, "", 4
Attached, updated versions of your picture with some transparency so there the button behavior is still visible. xy2.png has 0 white background while xy3 keeps the white background within the contours.
https://mfbim.fr | https://youtube.com/@mfbim | My GDL course on Udemy, try it !
AC24 FRA 7600 - AC26 FRA 4027 | MacBook M1 Pro
MF BIM
Hi @Sofiane LPAF ,
cell_width 	= 124
cell_height = 93
choices		= 4
				1, "", 1,
				2, "", 2,
				3, "", 3,
				4, "", 4
I thank you very much for your help, clear and precise, it works very well. Thank you once again for your time, see you next time!!!
Good to know it worked ! If you can, please mark my previous post as solution so people see your question as solved if they look for the same answer 🙂
I would also advise to resize the pictures beforehand so they look cleaner in the UI. If the resizing is done with GDL in Archicad, the .pngs will look blurry.
