ā2014-08-27
05:41 PM
ā2022-09-26
10:58 PM
Daniel Kassai
Solved! Go to Solution.
ā2014-10-20 11:34 PM
ā2014-10-21 07:26 PM
Karl wrote:So, we can tell other users
Thus, people can still provide instructions here about what lines of code to insert, as I read this... as long as the reader does the insertion/editing themselves and does not distribute the result.
ā2014-10-21 07:29 PM
ā2014-10-21 07:46 PM
Karl wrote:This seems an overly cautious interpretation of what Laszlo said. I read what he said as not allowing the redistribution for resale. (i.e. commercial gain) How would reposting a modified object for FREE violate the license terms? I don't think it would, at least as it has been presented here.
So, we can tell other usershowto modify an existing object as long as we do not post the modified object?
ā2014-10-21 09:51 PM
laszlonagy wrote:I was focusing on the above statement, Richard ("own purposes and use"). So, maybe more is possible, but at least we can give the lines of code to modify an object which is mostly what has been done here over the years...
The most important point:
A person or a firm is allowed to freely modify any GDL objects within the default ArchiCAD library for their own purposes and use.
ā2014-10-21 10:17 PM
ā2014-10-22 12:35 PM
ā2014-10-23 08:03 AM
ā2014-10-24 04:02 AM
Ilder wrote:If you mean you would use some GS macros, then if those macros are in the standard library and you do not re-distribute them and your object's code is 100% newly written by you, then yes, you can distribute/sell your object.
i need to understand, if i want to make a new object, something complex like a window.
I don't want to overwrite the GS object so let's say i use save as and give it a new name. Doing so i can use some GS code parts (without the object won't even work).
The new object can be redistributed, and make profit from it?
ā2014-10-27 07:03 PM
