2019-02-13 05:28 PM - last edited on 2022-09-26 10:57 PM by Daniel Kassai
Solved! Go to Solution.
2019-02-28 10:16 PM
2019-03-01 09:50 AM
Moonlight wrote:What I was really interested in knowing was your reason for preferring a PDF to the GS' current approach - in terms of everyday working practice.
Just make a comparison between McNeels Rhino's API and that of ArchiCAD. There is a more people and companies that already are using McNeel's Rhino API than that of ArchiCAD's, and by this way you may encourage more people to adopt it, it's something like throwing the ball over their wall. And about the size, don't forget that the size of ArchiCAD's user manual is 600+ pages
2019-03-01 02:27 PM
2019-03-01 10:33 PM
2019-03-02 12:01 AM
2019-03-02 01:02 AM
Moonlight wrote:
I would like to thank you for explaining the part of the API in relation to Rhino users, you have just expressed my idea in words that I didn't know how to express.
Moonlight wrote:
But most important Graphisoft, just don't recreate past error in new ways and in new dates, for example, are you aware that until today the most important information source to learn GDL, is "The GDL Cookbook" written by David Nicolson-Cole, a 20 years old book ????!!!!
Moonlight wrote:
By the way, GDL should be defended as the excellent BIM object creation tool, not that of Revit Families.
2019-03-02 03:07 AM
But most important Graphisoft, just don't recreate past error in new ways and in new dates, for example, are you aware that until today the most important information source to learn GDL, is "The GDL Cookbook" written by David Nicolson-Cole, a 20 years old book ????!!!!The first GDL manual I have ever read was that of ArchiCAD 6 in 2000, and after few year I got my hands on that of David, but what I meant with that quote is that these two manuals were made to encourage people to use/learn GDL, by using simple language that they can understand and with ever bit they raised the bar a little bit, so wen you finish reading them, you already know enough not only to create new stuff but also to know when/where/how you ask the question you need even if that means you raise the bar quiet high for your capacity at the time.
2019-03-02 09:34 PM
2019-03-04 12:27 PM
LIBRARYGLOBAL is a function that should be used in 2d and 3d to reach the parameter values of an MVO dialog, and change the object’s behaviour based on that. It should not be used in parameter script, and it does not make any effect on parameter values of placed objects.Source:
2019-03-04 05:24 PM
