Nader Belal
Mentor
Questioning about manuals ?
Where is the place that I can propose the editing for manuals ?
For instance, right now, when revising COOR, COOR{2}, COOR{3} GDL commands, there was no mentioning that the these take effect after defining a specific body.
80 Replies 80
Nader Belal
Mentor
@Joe Putnam
Just stumbled upon this in #Rhino ... And I think that reinforces our own views
https://discourse.mcneel.com/t/learning-revit-or-archicad-for-rhino-grasshopper/67650/10
Nader Belal
Mentor
GDL Manual, Page 494 - Table 6. Variable name prefixes
Add a prefix for angle, may be ang
Nader Belal
Mentor
Project2{4}
The examples that have been used and explanations are cryptic, and unclear. Needs to be redone from the its basis
Nader Belal
Mentor
GDL needs a special library section only for algorithmic solutions ...
For example, there is an algorithm that a member have shared in this forum to create a discontinued line for 3D representation, and it's fantastic.
Nader Belal
Mentor
The GDL manual falls really short in two aspects
Forward & Backward GDL Migration, it just lacks meaningful content
Nader Belal
Mentor
https://bimblog.bondbryan.co.uk/ifc-2x3-element-and-type-classification-the-plain-language-a-z-list/
The content of this post by Bond Bryan, lays out the foundation for choosing the best IFC 2*3 classification for the most common elements found in the different projects.
I believe that Graphisoft must create a special chapter, with similar content to help users choose the best subtype for the intended object.
Nader Belal
Mentor
In ArchiCAD standard electric MEP objects, you will need to set few standard parameters for:
  • Electric Current Types (AC/DC)
  • Electric Current Amperage
  • Electric Current Amperage Unit
  • Electric Current Frequency
  • Electric Current Frequency Unit
Nader Belal
Mentor
This thread insights must be included, their is no excuse to ignore it Graphisoft
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=67959&p=302331#p302121
Nader Belal
Mentor
To Graphisoft
An example like this one should be added to the GDL manual
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=68254&p=303334#p303334
Nader Belal
Mentor
TO Graphisoft
You Should Add this under "GDL Style Guide"
Local Coordinate "L" must return to the Global Coordinate "G" after its consumption by the general or subroutine script.
As an exception, it's admitted that you my opt out of this procedure if the coordinate transformation have taken place within a group, since that Local Coordinate "L" will return to it's previous location prior to Group definition
