maurotrotta
Redefine favorite objects
I have a list of favorite windows for a specific projects, but sometimes I change something in one window and I would like to redefine that into my previous favorite but the redefine opton is turn off. Then I have to open the settings for my favorite, make all the changes I already did in the window and then redefine the favorite. It would be faster if I can change a window and transfer those changes into an already made favorite. It´s that possible?
1 Solution
maurotrotta
3 Replies 3
I have just closed Archicad but I am pretty sure if you have your changed window selected, then you can redefine the favourite.
hevi
Ace
Redefining is possible. Are you using the favorite palette or the tool dialog?
maurotrotta
Thanks for your quick replies. I found the solution here:
https://help.graphisoft.com/AC/26/INT/_AC26_Help/020_Configuration/020_Configuration-60.htm
